Haybine Use Question
steve in PA
05-23-2006 13:12:42
Can I run a Haybine in a tractor that don't have remote hydraulics? I got a early 70's MF with live pto, almost 40 hp, but no remotes and wonder if my only real choice is a 3-point sickle bar. I got about only 12 acres of grass hay. I'm considering an older 7-ft NH haybine, but have not used them before. Any advice for a limited budget?
Josh in PA
05-24-2006 03:58:29
 Re: Haybine Use Question in reply to steve in PA, 05-23-2006 13:12:42
I really think you need hydraulics. In good hay it would clog up everytime you tried to turn if you didnt pick up the mower. I have a pretty nice NH 488 and it has to be picked up to go over already cut hay.
Josh
old
05-23-2006 16:52:57
Theres a hand op. ratcket thing that can be used in place of a hyd cylinder. I used one for a number of years with one. Only problem is you can't lift it when you make corners but thats no big deal
steve from mo - dangit!
05-23-2006 13:24:50
 No remote? No problem! in reply to steve in PA, 05-23-2006 13:12:42
If you have a three-point hitch, you can plumb in a remote. There are articles on here about it - the process is similar to a Ford tractor.
