Clutch on a large bushog
chuckinnc
05-23-2006 07:34:50
I have a heavy duty Hardee bushog that keeps
snapping the pto shaft, the clutch must not be
working. I cant figure how it should be adjusted
there are several round disk in between some 6 or 8 sided plates, the plates seem to be locked in place by the clutch housing? Anyone ever had
experence with one like this?
Glen in TX
05-23-2006 09:56:58
 Re: Clutch on a large bushog in reply to chuckinnc, 05-23-2006 07:34:50
Take it apart and get it loosened up. May need some new clutch discs in it or other parts. Can get aftermarket discs and clutch parts through a TISCO dealer, woodsonline.com or a A&I dealer.
Nat 2
05-23-2006 08:13:25
Are the plates and disks squeezed together by several bolts with springs? If so, simply loosen the bolts to reduce the pressure on the clutch so it will slip.
The plates and disks may also be rusted together so they can't slip if the mower sits outside in the weather.
