Calling Hay Dr
farmallbee
05-23-2006 04:04:50
I am looking to upgrade from a haybine to a drummower/disc mower? I cut about 50 acres and will take real good care of the machinery (maintaince and useage)
Question-What are your feelings of the fort disc mowers
and what about a drum mower-Local guy has Agro???
Thanks for the help and knowledge
Hay DR
05-23-2006 06:25:23
 Re: Calling Hay Dr in reply to farmallbee, 05-23-2006 04:04:50
Fort P is part of the ARGO family of companies. The Fort/Morra mowers are a copy of a Kuhn disc mower. This is a conventional oil bath mower. Fort/Morra's hitch is one of the hardest to hook up in the industry. They could not copy Kuhn's hitch which also means the balance of the mower is totally different than a Kuhn. Fort/Morra has no parts in common with a Kuhn. Darrell Harpe, Buy Smart and Agri-Supply are their primary distributors in the USA. Parts support and dealer support is a consideration. Fort is probably the best of the Kuhn imitators but is not close to a Kuhn.
When purchasing a disc mower, the first consideration is your tractor. How much PTO HP do you have? How much does the tractor weigh and what is the weight distribution? What size mower can I safely operate? Once you figure out your possibilities then how much production do you need? The most popular size disc mower sold in the USA is a 6 disc unit. A 6 disc unit usually measures around 8 feet. An 8' disc mower disc mower only gives you about a 13% capacity gain over a 7' mower. You will notice a gain in production when you would jump from a 7' to 9' mower but usually not just jumping one foot in size. Being you have 50 acres, a 7' disc mower would work fine for you but if you have the HP and want to go bigger you can. 7' & 8' disc mowers have greater resale value than 9' and above disc mowers. The larger mowers are usually used by the larger operators and are well used when they are traded.
