RodInNS
05-22-2006 14:08:31
Re: CLAAS Round balers,Rod in NS? in reply to Kent in NB, 05-22-2006 05:12:15
Huuh. Fort eh? I haven't dealt much with them. The last contact I had with them was last fall. I was looking for some parts for an old IH combine. They weren't particulairly enthusiastic about that... but nobody is when it comes to a 615... They all say OH, one of them? So I dunno. They might be OK with newer stuff. For the most part, I haven't had a lot of trouble with my 44S. The biggest thing I had to wait for was rollers, which wasn't too long. However, that was close to 10 years ago. We also bought them ahead, and had them when the failure happened. They were stone damaged, and we knew their ticket was up.... The only other stuff I've changed is pickup teeth, guards, pickup bearings, and the cam follower bearings. Any bearing on the machine can be gotten through Coastal or Kinecor. The other stuff I keep on hand. Actually, I did a major overhaul of the pickup, and I just keep some old guards around, and always some new teeth. Otherwise, I wouldn't expect much to wear out or break. The only real failures I've had were pickup bearings, due to hay wrapping on the shaft and cooking the bearing. Keep the chain oilers up and working too, and if you do need to change chain, get the best quality 60H, 80H or 100H if it has 100. Always get the heavy side link chain. Regular chain doesn't stand up, and chinese chain is eaten before breakfast. Best of luck.Rod
