JD dealer NH 258 rake
Flurette Farm
05-19-2006 19:42:35
During the off season I bought a NH 258 rake from the local JD dealer. Though it was rough, weathered, had a flat on the dolly and one on the rake itself the salesman told me he�d tried it himself before the tires went flat and it worked fine. I also purchased a wagon from him and the rake was loaded on the wagon and I towed it home.
When I got it home I fixed the flat on the dolly, bought new tires for the rake and when mounting found 1 wheel was 15� per spec and 1 was 14�. Bought a new wheel. Replaced about 20 tines that were worn or gone. Realigned the stripper bars, cleaned, wire brushed and painted and stenciled the unit. It looks great.
Herein lies the problem. I pulled it to the field put into gear and the gearbox is stripped. My question is what should I expect from the JD dealer. I�m not a big JD guy and I�ve only spent approximately 30 thousand there in the last 5-6 years. Fortunately I have a 256 that works fine its just to narrow for my cutter width to work best.
Any advice?
TomTX
05-20-2006 05:45:34
 Re: JD dealer NH 258 rake in reply to Flurette Farm, 05-19-2006 19:42:35
Tell them exactly what they said about being in raking condition, show them the gears/bearings that are shot. Try to get them to furnish the parts, you the labor.
Next time get it home, try it out quickly, tear down if needed, before painting and stencil. MHO Tom
Bret4207
05-20-2006 05:44:49
If the salesman said it worked and it doesn't that sounds like it was a lie to me. Go from there.
Randy as in Randy-IA
05-19-2006 20:59:40
Ask 'em . Money talks and it sounds like you've spent some with them . If it was me ask'n 'em they'd laugh me out the front door . Good luck . ...Randy
