Sharpen sickle bar knives or replace?
Illinois Farmal
05-19-2006 18:50:03
I was just wondering if most of you with sickle bar mowers ever sharpen the knives or just replace them? Mine are the serated knives. If you sharpen, what is the best way? Thanks for all the help.
Leroy
05-20-2006 18:31:44
 Re: Sharpen sickle bar knives or replace? in reply to Illinois Farmall, 05-19-2006 18:50:03
The trick to good sharpening any knife without burning is to use a sandstone wheel running slow, think foot pedal, and running in water and you will get a good sharp edge without any burning. Smooth and underserated sections were sharpened all the time, top serated are not made to sharpen but if you watch how you do it you can still sharpen them once or twice before you have to throw them away
Nebraska Cowman
05-20-2006 03:47:48
Under-serrated sections can be sharpened and for cutting grass hay they work better sharp.
over-serrated are self-sharpening.
third party image
Even bad boys are just as good as they can be
Hugh MacKay
05-20-2006 02:45:52
During my farming days we had time and it paid off to sharpen mower sections. I annually mowed 35,000 bales per year. I always had 3 knife section bars on the go, sharpened them all by hand with a carburendum. The carburendum does a superior job of sharpening. Just clamp the bar in a vise on the flat and go at it. I have changed for freshly sharpened cutters 3 times per day, it pays off. We learned that with horses, dull cutters would play the horses out.
I do agree with Randy, in fact if you have top serated sections, see the nearest scrap dealer, he will give you exactly what they are worth. Once the sections are ground to a point you may as well replace them. If you hand grind a bar every 15 acres, a 9' haybine bar only takes about 20 minutes.
Remember if dull knives played the horses out, they just created excessive wear and breakage with the tractor. Most broken pitman arms have been caused by dull cutters.
JMS/MN
05-19-2006 21:59:50
Of course you sharpen them- doesn't matter if they are serated or not. Just grind them to a smooth edge and cut grass. Serated knives do have an advantage, but they can cut fine with sharpening.
JJ. in B.C.
05-19-2006 20:44:34
Replace them, trying to sharpen serrated knives is a waste of time.
JJ.
Randy as in Randy-IA
05-19-2006 20:36:58
Hi , Kind of need to know if they are underserrated or top serrated . I don't think the top serrated ones can be sharpened but the underserrated ones can . I tryed to sharpen my US with a 4-1/2" grinder with a sanding disc on it , a cut-off wheel and a regular grinding wheel . Nothing worked for me to my satisfaction . I couldn't keep the teeth ( serrations ) from getting to hot . So I just bolted new ones on . It didn't take very long and cost less than $25.00 for 35 new sections and the new bolts to put them on . I put the knife-back over two pieces of white oak , started the bolts out with a good whack of the hammer and then used a punch to drive them the rest of the way out . Did the same thing to put them back in . The top of my hayrack made a great place to do it with plenty of room to work on it . ...Randy
