Land Pride Disc Harrow
Land Owner
05-17-2006 19:15:34
I purchased a used "Land Pride" DH25 (or equal) disc harrow and downloaded its manual from the Web. Its bearings are shot and there is corrosion on the nuts and bolts. I have purchased bearings and am motivating myself to restore this piece of equipment to some simblance of its former use. I'll torch cut the keeper nuts off and replace them with new ones if the breaker bar and "Liquid Wrench" fail to accomplish removal.
There are two inherent difficulties with this disc. 1.) I am NOT a farmer and 2.) it is too tall and doesn't lift more than ~2-inches off of the ground.
I am towing it behind an MF 275 (67 HP) but there is no more static adjustment in the lifting arms of the 3-pt. hitch (no more drilled holes toward the tractor to effect an upward lift in the arms). Perhaps there is a little more dynamic adjustment (screwing the lifting arms tighter into the threaded bars) but not much. The top link is attached to the lowest of 3 location points on the tractor. Tire inflation is good. Tire size is as recommended by the manufacturer. Not "turf" tires.
I suppose I could use 18" blades, but the disc is designed for 20" to 22" blades. It is currently fitted with 22" blades most of which are in one piece and good shape so replaceing all of them w/20" blades is not the way that I would like to go.
I'm "living with" tough trailering and even tougher maneuvering around uneven terrain. Any suggestions?
Land Owner If it was easy, anybody could do it."
Tx Jim
05-18-2006 03:43:13
 Re: Land Pride Disc Harrow in reply to Land Owner, 05-17-2006 19:15:34
Have you checked to see if your rockshaft is rotating full up? With nothing on 3 pt hitch raise full up and see if 3pt can be lifted any more by hand. If you can raise 3pt by hand linkage needs adjustment. Tx Jim
Land Owner
05-23-2006 19:02:03
 Re: Land Pride Disc Harrow in reply to Tx Jim, 05-18-2006 03:43:13
If the 3-pt. hitch will still raise when it is in the UP position, what would be the recommended adjustment?
davpal
05-17-2006 22:30:28
Is the top link adjustable? I ran into the same problem with my 9n and 6 1/2 foot disk. I cranked down the top link a few inches and it lifted the disk much higher off the ground which made it easier to load on a trailer and also to navigate around on uneven parts of the yard. When you get to where you want to disk, just unscrew the top link to level the back of the disk back out and go to disking. Good luck.
