460 Fix or not
KCkruser
05-17-2006 09:50:57
got a 460 haybine, broke the clutch and gear out that drives the lower roller, cant figure out how to get apart can you get repair manual,or is it not even worth fixing, Can buy 469 for about sme price as parts, havent seen 469 yet so don"t know what condition I only do about 10 acres so can"t afford to much $
old
05-17-2006 10:42:40
 Re: 460 Fix or not in reply to KCkruser, 05-17-2006 09:50:57
Where you at?? I sure could use your 460 since I still run one every year. And yes you can still get books for it
KCkruser
05-17-2006 10:45:25
 Re: 460 Fix or not in reply to old, 05-17-2006 10:42:40
im in dubuque ia, have you had problems with yours plugging in down hay
old
05-17-2006 10:52:49
 Re: 460 Fix or not in reply to KCkruser , 05-17-2006 10:45:25
If your saying it plugs when you go over an area that has already been cut yes they don't like to go over an area twice. To go over an area a second time you need to raise the cutting head up so it goes over the cut hay and doesn't try to cut it a second time.
KCkruser
05-17-2006 11:04:12
 Re: 460 Fix or not in reply to old, 05-17-2006 10:52:49
NO Mine seems to plug when cutting in wind blown down hay but only when cutting into the direction its blown down, I just got a operators manual yesterday noticed reel adjustment is suppose to help this, looked at mine reel is adjust all the way back toward roller
JMS/MN
05-17-2006 17:25:06
 Re: 460 Fix or not in reply to KCkruser, 05-17-2006 11:04:12
If you are cutting down hay, you need to slow the ground speed when going in the direction that it lays. Give the reel time to pick it up and pull it in. No way to get around that.
old
05-17-2006 12:25:22
I almost never run it to that type of problem, I live in a valley so I don't get much wind. But yes I could see it giveing problems. I have a lot of crown vech and that can be a big problem. I have even had to cut the stuff off the roolers at times because it will ball up and cause problems. I do pull my 460 with an Oliver 77 which has live power sao that does help a lot
Jimmy King
05-17-2006 10:19:36
Go with the 469 it has a better float system for the header.
Josh in PA
05-17-2006 10:02:11
A 460 is pretty old, around here even a good one would probably bring less than $100. I think I would try to upgrade instead of fixin up the old one. The 469 is supposed to be a good machine, but watch the rolls, as they are real expensive to replace. ($1800?) A 469 is very similar to a 488 which i have, and it is a real good machine.
