JD Baler
Crittr
05-17-2006 05:29:53
Can anyone give me the dimensions of the feeder arms on a JD 214 baler? seems the prev. owner got it out of time and sheared the arms off
Thanks
Myrl (PA)
05-18-2006 03:56:19
 Re: JD Baler in reply to Crittr, 05-17-2006 05:29:53
I have a 214T patrs baler out here. E-mail me if you dont find one but also check your plunger to make sure it did not get bent where it hit the feeder forks. If it did it could catch a needle and ruin your whole day
Tx Jim
05-18-2006 03:55:00
Crittr,if your talking about dimension for timing,bring plungerhead rearward on compression stroke till "face of plungeer head" is centered in first feeder fork slot,measure from LH end of feeder fork slot to tip of feeder fork should be 10-12 inches. Tx Jim
old
05-17-2006 08:15:43
If you need a set I have a 14T and 24T parts balers. E-mail is open
