JD 640 hay rake tires
anderson farms
05-16-2006 23:36:54
Does anyone know the correct tire size for the rear tires on a JD 640 rake? Just bought rake and need to replace tires. It has old car tires on it that are bad. Thanks for any help
TomTX
05-18-2006 06:19:51
 Re: JD 640 hay rake tires in reply to anderson farms, 05-16-2006 23:36:54
Not familar with that model number, but if it is a ground wheel powered rake then an old car tire will not rake properly. You will need special tires. Regular tires will slip when raking heavy loads. Tom
