ID for JD plow
Matt B
05-16-2006 13:28:25
I have a JD 2-14 trailer plow, with rope trip mechanism. I am not sure what model number it is. I could make out "623" cast on one of the main beams. One of the points broke off, and the trailing wheel fell off, I need parts for this, but am not quite sure what model number to look for parts under.
The plow has a solid steel disc for a traling wheel, and spoke wheels.
Thanks,
Matt
Myrl (PA)
05-17-2006 05:28:48
 Re: ID for JD plow in reply to Matt B, 05-16-2006 13:28:25
Matt I have a lot of parts for them ole JD trailer plows. If you are close to PA drop me an e-mail I will help you if I can
Maine Fordson
05-16-2006 13:31:01
Sounds like a Deere #44 to me. Manuals pop up on eBay from time to time.
Leroy
05-17-2006 05:29:46
 Re: ID for JD plow in reply to Maine Fordson, 05-16-2006 13:31:01
It would not be a model 44 because they did not have cast beams with munbers in them, they were a flat bar bolted together beam. It would be a 4B or a 52, the 52 only had an open type clutch, the 4B early had the open type clutch, later had a closed type clutch same as the newer 44 had. The lift wheel on a 52 was 28" diameter, the 4B was 32" diameter, if you will check the archives on both the implement and John Deere boards you will find posts that give the beam numbers for both the 52 and the 4B
Matt B
05-17-2006 20:13:46
 Re: ID for JD plow in reply to Leroy, 05-17-2006 05:29:46
After looking at the implement photos, it is a 52 on rubber, no doubts at all!
Thank you all for helping point me in the right direction.
Thanks!
Matt
Bob Collins
05-19-2006 04:51:47
 Re: ID for JD plow in reply to Matt B, 05-17-2006 20:13:46
Matt it is not a #52 if it has 623 stamped into the forged beam. It is one of the "4" series most commonly a 4B. True it looks like a 52 but a 52 has only 3 braces between the beams vs. 4 on the 4B. 4B has a lifting spring because it is heavier #52 has no lifting spring. #52 has 1 1/2" diameter axles and the 4B has heavier 1 3/4" axles. More differences but those are the easy spotters tips for today. You'll want parts catalog PC-253.
