IH toolbar planter sprockets
RC Farms
05-16-2006 06:09:32
I've have an older 4 row IH toolbar planter that has three sprockets, and a lever that has 2,3,4 settings??? I purchased the seed plates for sweetcorn with 16 cells for flat seed sweetcorn (plate type recommended by the seed mfgr, C 65-16 or 24 cell) because I don't want the 24 cell that drops the seeds closer to each other...but now which sprocket to use? Also on a previous post I had trouble with a toolbar chain coming off one of the planters....problem was that chain had one more link than the other three...had 56 links should have 55.
OH Boy
05-16-2006 17:00:35
 Re: IH toolbar planter sprockets in reply to RC Farms, 05-16-2006 06:09:32
Lift the planter up (jack it up or lift it with three point hitch) and turn the drive wheel one revolution and count how many seeds drop.
Measure the circumference of the drive wheel in inches and divide that by how many seeds dropped and you will know what your spacing is.
Allan In NE
05-16-2006 08:34:13
RC,
How's about putting on the center sprocket and check when you start to plant. If it is too thick or too thin, adjust accordingly?
Allan
RC Farms
05-16-2006 09:58:42
 Re: IH toolbar planter sprockets in reply to Allan In NE, 05-16-2006 08:34:13
Thanks, guess that is the way to go..trial and error.
