electric over hydraulic brakes
carroll
05-15-2006 16:47:17
looking for a wiring diagram for 2001 gmc truck for electric over hydraulic brakes.i have a new 26 foot tri axle cattle trailer need to get wiring hooked up on my truck can anybody help thanks
Jason Simmerman
05-16-2006 06:05:45
 Re: electric over hydraulic brakes in reply to carroll, 05-15-2006 16:47:17
If you have a factory tow group on the truck then you should have a factory pig tail under the dash someplace to let you install a brake controller. If you have the factory tow group you just need to add the brake controller. If you don't have the pig tail for the controller you can get one from any local RV place for about $15 - $20 or so.
ET
05-16-2006 04:38:09
There may be a short wire whip that came in the glove box when the truck was new. It plugs into the wire harness under the dash to hook the electric brake controller to. In the rear of the truck there should be a taped up pigtail of wires that wire in the trailer receptical. Not all trucks came from the factory with trailer wires in them, if yours didn't just follow the instructions that came with the electrice brake control.
