Mower for Farmall H
DaveK
01-25-2000 22:16:34
I have recently purchased a 43 Farmall H with a PTO but no three point nor hydraulics. I would like to use it for mowing construction lots. What is a source for a pull behind sickle mower or a pull behind brush hog. I think I would prefer the sickle type. Does anyone make these today or am I limited to the used market. Any and all advice will be greatly appreciated.
Roger
02-04-2000 07:15:51
 Re: Mower for Farmall H in reply to DaveK, 01-25-2000 22:16:34
Dave,
I was just wondering if your 1943 Farmall H is sn. 137049. My dad bought this tractor new in '43 and I would like to locate this tractor.
My ph. is (607) 756-8213.
Thank you very much for your attention.
Roger
t
01-28-2000 11:55:42
I would get a brushhog type. The sickle will be a pain when trying to mow around stuff, especially since its not 3pt mounted. Also, any little piece of metal or something hard sticking up will take a good notch out of a sickle section. And with most of those older seckles, you have to take the whole bar out to replace a section easily. You can replace them by taking off the guards and using a block under them when setting the rivet. But that can be a pain to do.
Another thing is that a sickle mower won't go through real thick, matted, heavy grass, It'll cut it, but the guards will get tangled and the bar will break away(like when you hit a large rock, stump, etc.)
B.C.
01-27-2000 05:49:54
One of the neighbors up home used a rig exactly like The Red sent a image of for mowing hay. Worked fine. If you're gonna mow lots where there will be debries, brush and so on be sure that the mower has a slip clutch. Most Deere mowers of that vintage did. Deere (and others)is pretty good about parts support.
If you did go the rotary route I think you would want to get an over-runing clutch for the PTO. Also, depending on rocks, debries and so on the rotary blades might eventually need more maintenance than a sickle bar would.
The Red
01-26-2000 13:21:19
third party image
In used stuff, this is my Grandpa's 1941 Farmall H (which a neighbor owns and has NEGLECTED) with a JD #5 sickle bar mower attached. I have seen this type of mower for around $100 to $200. A lot were built so parts can be found. You can also get some new parts from Deere. The mower cuts pretty darn good.
JakerMan
01-27-2000 11:23:42
 Re: Re: Mower for Farmall H in reply to The Red, 01-26-2000 13:21:19
So how much have you offered him to get that family treasure back?
The Red
01-28-2000 03:15:20
 Re: Re: Re: Mower for Farmall H in reply to JakerMan, 01-27-2000 11:23:42
He won't part with it. He and his brother had a feud going and he bought it out from under his brother's nose for $300 in 1983 from Grandpa. His brother is now in poor health. If he passes on, I suspect I will own it.
Nice looking setup.
01-27-2000 06:31:09
Thats the way I like to see these old girls,
I think they look good painted to, the only reason
I painted mine was to keep it from rusting, I'd rather buy that one than one just painted, around here they cover a lot of ugly with a little paint.
My neighbor a small case last spring after running it a couple days the body filler came off the block leaveing a 4 in crack. So to my that looks great. Jeff
paul
01-26-2000 21:02:49
Glad to see he got the gas safety cap.
(Case has a recall on them, send in your serial number & they will send you a free, VENTED gas cap.)
--->Paul
The Red
01-28-2000 03:12:36
 Re: Re: Re: Mower for Farmall H in reply to paul, 01-26-2000 21:02:49
It only has the gas safety cap because I had an extra one and stuck it on there.
Burrhead
01-26-2000 09:42:03
I know Bushhog still makes a trailer type bushhog and you can get a new sickle mower too. I would recommend the bushhog for construction lots and clean ups for a sickle mower will not stay together using it for clean up. The smallest piece of construction debris will totally tear up a sickle, a bushhog will keep going.
The price of a new sickle is too high. I priced a new 6' for hay cutting last year and it was $5400. They price them so high to make you buy a new disc bar cutter. They cost nearly the same price.
