Choosing a sickle bar mower
Lincoln
05-14-2006 16:47:07
I am needing a sickle bar mower. Are there any advantages between a pull behind type and a 3 point mounted type? I'm looking at a JD 450 9' pull behind, and a Dearborn(Ford) 501 mounted type. I was told the Fords don't work well on other tractors for some reason. Any truth to this? Thanks for your help
nw_bearcat
05-16-2006 05:30:36
 Re: Choosing a sickle bar mower in reply to Lincoln, 05-14-2006 16:47:07
I haven't been around the 501's as much but some of the Ford mowers did not play well w/ other makes of tractors. We've got a 515, and to use it, you must have the breakaway bracket that connects the breakaway assembly to the tractor lift arm. Those are kind of tough to come by(easy enough to make though) but the originals don't fit on some makes of lift arms.
Comparing the two mowers you have picked out, you are looking at a 40+ year old Ford with a pitman stick, and probably a 7' bar, and at worst, a 15yr old JD, with a 9'. I have a bias against pull type mowers if you have a 3pt tractor, but a larger bias against a pitman stick mower if i have a choice. We're running a Ford 515-belt drive, and three JD350's-3pt, 2 9', and one 7', and get along pretty well.
Ghostrider
05-15-2006 05:24:09
I used a John Deere model 39 3-pt mower for years. About the only disadvantage was hookup time. If money is not a huge object, a pitmanless mower would be a great choice. I would think a Ford 501 would be fine on most any tractor with a good 3-pt.
wolfman
05-14-2006 17:02:00
A pull behind is kind of useless on steep ground as it will drag a little off the hill. Had one once and had to bolt wheel weights on it's wheels.
504
05-14-2006 21:54:47
 Re: Choosing a sickle bar mower in reply to wolfman, 05-14-2006 17:02:00
The Ford will work fine if you have a draw bar and 3 point
