Sanity Check - NH 258 Gearbox Oil
e
05-14-2006 10:43:32
I'm in the process of fixing a gearbox seal on a NH 258 rake. When I pulled the cover, there was water and brown "greasy" goo inside. I just want to make sure the factory recommended lube is 80w-90 gear oil and not grease. I'm almost postive that it should have gear oil, but I don't have a owners manual to verify.
Thanks!
Steve from New Holland
05-15-2006 04:24:18
 Re: Sanity Check - NH 258 Gearbox Oil in reply to e, 05-14-2006 10:43:32
In 1977, New Holland officially switched from gear oil to 2 tubes of grease gun grease. Steve (p.s. Actually, they told us one tube in 1977, but sometime around 1980 they upped the amount to 2 tubes.)
mn.Chuck
05-14-2006 17:12:35
The original manuals called for gear oil but later
the company recommended gun grease. No rake gets
used when -20 degrees. We had good success doing
this to all rakes at the dealership. Chuck
paul
05-14-2006 23:24:59
 Re: Sanity Check - NH 258 Gearbox Oil in reply to mn.Chuck, 05-14-2006 17:12:35
Exactly what I"ve heard.
--->Paul
3010JD
05-14-2006 16:56:11
Just did the same thing with mine. Had the same grey crap and water in it. NH dealer said it took gear grease. Its thicker than gear oil - not as thick as grease. Comes in a quart bottle with spout and you squeez it in.
R.J.
05-14-2006 14:14:24
I have a 258 and i always use gear oil and have had no problems in the many years that have run this rake.
Sgt. Rock
05-14-2006 11:52:55
I have used a lot those rakes and when I worked on the gear boxes, my local dealer always said to fill with a good grease and check it once awhile to make sure it was full. Hope this helps.
Blue guy
05-14-2006 11:33:01
I am not sure about the 258 but, the 256 calls for grease. I thought it should have gear oil also. New Holland dealer says grease ONLY! I had my gearbox apart a while back and I drilled and tapped a hole for a grease fitting between the pinion bearings. Once I filled it with grease then I install the cover plate. Then every once in a while I give 1 or 2 shots of grease. That helps keep any water pushed out.
