Case sickle mower question
Scott(MO)
05-13-2006 00:49:39
Hello , I'm trying to find out what model case sickle mower I have. A buddy gave it to me as a project because it busted the top pulley bracket. But, I can't find what model of mower it is. It is fully mounted (3point or I guess Eagle hitch). It has the breakaway latch for the bar (in case you hit a stump it will trip a latch and let the bar swing around. It runs by a wood stick pitman and has stands so you can unhitch it and it will stand up alright. It probably has a 7' bar on it. I know that is a pretty vague description but does anyone have any idea what it might be or tell me where to look for the model number? Thanks.
Scott
charley hellickson
05-13-2006 21:06:45
 Re: Case sickle mower question in reply to Scott(MO), 05-13-2006 00:49:39
hi scott. i please need to know one thing about the mower. does it have a triangler shaped sheet metal where every thing kinda mounts on like the pto and the drive pulleys with the pitman arm on the backside or is it an open frame work type? the sheet metal one is a model 10E. the other one might be what they called an HE7. hope this helps. charley.
Scott(MO)
05-16-2006 03:31:49
 Re: Case sickle mower question in reply to charley hellickson, 05-13-2006 21:06:45
Hello Charley, I don't think it has the triangular sheetmetal that you are talking about. I would call it an open frame. I saw some pictures of some Case mowers on the internet and it kind of ressembles a #7 mower (I think?) (like E-7,EH-7, EVAS-7,..) Does this sound right to you?
Scott
Leon in Mn.
05-13-2006 21:00:28
Not sure of the model, but I have one that fits that description that is in the scrap pile. I think it might be a model 20? Does that sound right? I know it attaches to the lift arms and it has an arm that also attaches to the hitch for lifting. Let me know if I can be of some help with the parts. Not much left of it.
Leon in Mn.
Scott(MO)
05-16-2006 03:35:58
 Re: Case sickle mower question in reply to Leon in Mn., 05-13-2006 21:00:28
Hello Leon, Is there any way you can get some pictures posted on the internet. I definately could use some parts . The main PTO cast housing busted and needs to be replaced. Thanks.
Scott
