Orchard Sprayer for Case Garden Tractor
Ron in Michigan
05-12-2006 02:23:07
I picked up an orchard sprayer custom made for a Case garden tractor. It was made by the Kramer Sales and Manufacturing company of Maple Lake, Minnesota. As this is my first post to this forum, I am not sure how to post a picture with this post. If anyone can advise me on the proper procedure to add a picture with a post, and the best picture format to use, please do. The sprayer has around a 50 gallon tank on it. It rides on sort of a back-pack style frame attached to the tractor. An electric pump is used to pump the water through four hoses to spray nozzles located at the end of the air exhaust chute. A hydraulic motor drives the fan to provide the air flow. The exhaust of the fan goes through an adjustable chute that can be pointed to the left or the right. The four nozzles are inserted part way into the air stream to inject the water into the air stream. The nozzles have a piece that can be rotated to one of four settings to control the amount of water (chemicals) to be dispensed into the air stream. I believe that this arraingement is refered to as a canon sprayer. I plan on adding a boom system and a hand sprayer to this to make it an all-in-one sprayer. If I can figure out how to add pictures, I will add some or re-post this message with photos. I need help locating some of the plastic nozzles and their mounting plate but need to add pictures so someone might recognize the parts.
Ron
Flint Michigan
Ron in Michigan
05-12-2006 04:43:17
 Re: Orchard Sprayer for Case Garden Tractor in reply to Ron in Michigan, 05-12-2006 02:23:07
I posted a picture of the sprayer and a picture of the parts I need for the sprayer in the photo galleries under the implement photos section. Any and all help in locating these parts or the manufacturer of these parts would be greatly appreciated.
Thanks
Ron
JMS/MN
05-12-2006 05:28:51
 Re: Orchard Sprayer for Case Garden Tractor in reply to Ron in Michigan, 05-12-2006 04:43:17
Have you checked with Kramer Mfg.? 1-320-963-3733.
Ron in Michigan
05-14-2006 04:35:50
 Re: Orchard Sprayer for Case Garden Tractor in reply to JMS/MN, 05-12-2006 05:28:51
Yes I did. The gentleman said that they used parts from several suppliers, most of them small companies that are now out of business. He did not know where to get any parts. I believe that they (Kramer Man.) are not in the manufacturing business any more, that they are mainly a tractor sales.
Thanks for the reply.
