photo of my NH 477 sickle knife end
StuBC
05-09-2006 10:13:47
third party image
Here is a better way to ask my previous question. I bought new knives, and got at pounding out the rivets and got them all off and now its put back together point and I question my sequence of how to rivet on the knife head assembly to the knife back. My parts manual does not make it clear for me either. My question is length, how long should the sickle bar extend past the last guard? You can see in my photo that at the farthest reach, it does stick out quite a way now that I have it back together. I do not remember the sequence to align the two pieces for joining. This is what I came to but I question it, it seems unguarded.
Any help, please fire in there.
KEH
05-09-2006 18:32:14
 Re: photo of my NH 477 sickle knife end in reply to StuBC, 05-09-2006 10:13:47
New Holland found the half knife kept the blade from clogging on the end in heavy hay.
I assume you have the blade fastened to the wobble box. If so and if your pic shows the blade at the end of its stroke, I think you have it right. If you have the blade fastened up and you can turn it slowly without anything hitting something it shouldn't, then you have it assembled correctly and you can try it under power, slowly at first.
If you removed only the knife sections I don't see how you could assemble it wrong anyway. I only used a NH469 but I think the assembly would be the same. You have the half knife on right and the rest should be no problem. Hope this helps.
KEH
StuBC
05-10-2006 08:55:25
 Re: photo of my NH 477 sickle knife end in reply to KEH, 05-09-2006 18:32:14
Yes, the knife bar is attached to the wobble box. What I did was rotate teh wheel to the furtherst throw that put the knife that far out. Any more rotation and the knife comes back in.
I think I got out of confidence when I popped every rivet and had two pieces in my hand. So I had lost my nerve to how to bolt it back together. You can align those holes in a number of combinations to get a number of different lengths overall.
Then it seemed odd that it stuck out that far unguarded after I gambled and put it back together how I thought it would be.
KEH
05-10-2006 16:40:32
 Re: photo of my NH 477 sickle knife end in reply to StuBC, 05-10-2006 08:55:25
I think you are ready to go. Now you need a spare blade!
KEH
I don't know but,
05-09-2006 10:44:01
While I can't speak to your model, every sickle I have ever dealth with the point of the knife travels between two the center of two guards. I do not see a point for the half knife on the end???? Could you be off one guard? I'd think even if you were you still need a full knife on the end.
Now I have seen a pusher bar to push the crop away from the end to keep it from grabing hay and gumming up.
I would think it be as simple as lining up the last knife in the last guard, rotating the woble box to it furthest position that way and measuring the lenght needed (match up holes). Then swing woble box back the other way, pull last knife to the second to last guard, and verifing the measurement.
