small square baler
Big M
05-09-2006 05:59:30
Helping clean up an old farm. Found a small square baler, name says HayBiner. Who made it and is there any market for the old baler before the crusher gets it?
Thank you.
Jason Simmerman
05-12-2006 04:49:21
 Re: small square baler in reply to Big M, 05-09-2006 05:59:30
There is a data plate on it someplace around the flywheel eithor on the front of the machine or on the side just behind the flywheel. I'd get the info off of that or take a picture of it and post it. We'd be able to give you a better idea of what it is then.
Big M
05-18-2006 05:29:10
 Re: small square baler in reply to Jason Simmerman, 05-12-2006 04:49:21
Jason, send me your e-mail address and I will send you a photo of the New Holland baler. Got it out of the weeds.
Rexalot
05-09-2006 09:36:29
Where is here? I could be interested.
I would guess it"s a New Holland model to.
Big M
05-13-2006 04:55:59
 Re: small square baler in reply to Rexalot, 05-09-2006 09:36:29
The baler is a New Holland 271. It has been stored outside for years with no TLC. Will try and get it out of the weeds for a digital picture tomorrow. Jason, you were right as to where the ID tag was located.
Big M
05-09-2006 19:35:39
The baler is near Salina KS. I will stomp through the weeds to see if I can learn more about the baler. It has not been moved or used for years.
Josh in PA
05-09-2006 06:08:32
Maybe it says "Hayliner"? New Holland had hayliner on some of its older balers, but I'm not sure which models. NH made good balers, so if there are people in your area using older small balers it likely has some value.
Josh
