NH 311 switching to plastic from sisal
george gross
05-08-2006 18:54:21
I have a customer who wants plastic and I have only ever run sisal. What needs to be done to my 311 to run the plastic twine? Any help?
Catskill Pete
05-09-2006 15:33:08
 Re: NH 311 switching to plastic from sisal in reply to george gross, 05-08-2006 18:54:21
It should handle plastic without any changes except you may have to play with the twine disc tension a little, most plastic tends to run slightly thinner than sisal. One very important item is the twine cutoff knife has to be very sharp for plastic.
JMS/MN
05-09-2006 06:00:39
I think it involves changing to a different bill hook, which handles both twines.
RickB
05-09-2006 15:55:23
 Re: NH 311 switching to plastic from sisal in reply to JMS/MN, 05-09-2006 06:00:39
Although different billhooks are offered, unless the ones in the baler are worn out but not yet giving trouble, no parts change should be needed. As mentioned, twine disc tension may need to be increased a little.
RickL
05-09-2006 10:44:22
When I switched several years ago I didn't do anything other then drop them in.
