What Type you need Re:made their own 2-row cultiva
woodache
05-05-2006 11:44:28
What Type you need, Front mounted or 3 pt hitch?
What Kind of tractor. One of the best tractor for small farm cultivation is Framall A AV or C. These can use a front under side mounted, But if you have a Utility tractor like a small Ford or such 3pt mount is best because of clearence. 3 pt models or also known as a tool bar are mostly a moduler units that just bolt together using 2 1/4 square bar, a 2 or a 3 (best) row you can use heavy wall square yube, best to have provission for a set of gauge wheels for rear mounted cultivators, then just floot them so they run at constant depth. I just bought a used 3 pt used with 12 bar then got a shorter tube to use fo 5 rows on MF 35, I have gauge wheels and discs set up to hill up 3 rows,
Tim(nj)
05-06-2006 11:35:09
 Re: What Type you need Re:made their own 2-row cul in reply to woodache, 05-05-2006 11:44:28
Anymore, it seems the S-tines (AKA Danish tines) and sweeps are the easiest to find when you need to replace them. The local TSC has some in stock, so do some dealers, nobody has the C-type in stock.
paulinkansas
05-05-2006 14:51:49
It"s a 3pt 35 hp Deere. There"s a total of about 4 acres that need cultivating. There"s a local place that sells 2 & 3 inch 3/16" square bar. I"ll probably use that and make a rectangular tool bar to attach the shanks.
Which shank work best? The S type ones or another kind? I"m sort of ignorant as to the proper terminology.
