Help from the John Deere disc folks
RC Farms
05-03-2006 10:27:43
Ok, I have an array of of different emplement brands, but this is about my older JD tandum disc, it has hyraulics, 2 front set of discs and 2 sets in the back. I was discing the other day when I notice one of the front sets were out of the verticle sleeve and falling back into the side of the other front discs.The sleeve is more like a verticle socket and looks like it should have a pin through it (the other side doesn't) so my question is do I need to disassembe that one side to get it back in the sleeve/socket and doest it require a pin?
dairyman
05-03-2006 11:11:36
 Re: Help from the John Deere disc folks in reply to RC Farms, 05-03-2006 10:27:43
I had that problem with an old John Deere drag disc; what I did to get it fixed was place a jack under the frame of the disc and raise the frame without raising the gang then when it was high enough I moved teh gang into place and lowered the frame and set the disc into the pocket. you will need to put a pin in there if you don't want it to happen again. I hope that this helps you.
Dairyman
RC Farms
05-03-2006 12:43:54
 Re: Help from the John Deere disc folks in reply to dairyman, 05-03-2006 11:11:36
Thanks, i will use a jack and get the pins. I don't believe there is one in the other side either.
