Baler Measuring arm tripped.. at what end
kasparj
04-30-2006 18:51:30
Easy question for you experienced people...when the measuring arm is tripped on a JD 24 wire tie baler, is tripped when the sheave is in the hooked part of the measuring arm of when it hits the thingy with the adjusting screw??
Thanks
paul
04-30-2006 19:22:16
 Re: Baler Measuring arm tripped.. at what end in reply to kasparj, 04-30-2006 18:51:30
I've only ever walked past JD balers, but tripped is when the arm is up in the loose position, so the arm can move in toward the baler. As far away from the setscrew clamp thingie as possible.
--->Paul
