How close to set crimper rollers?
plumboy
04-30-2006 18:06:49
I"ve got some timothy/clover that has taken off!Its knee high and still a month from cutting.I have never done red clover,its stems and leafs are huge.I have a moco with rubber/metal rollers.I have never been satisfied with its crimping on alfalfa stems but this red clover has me worried so now I want to make sure its adjusted properly.How close should the rollers be?I"ll turn up the preservative on this stuff but it looks to be a problem.Any suggestions other trhan the rollers welcome.
IaGary
04-30-2006 18:53:45
 Re: How close to set crimper rollers? in reply to plumboy, 04-30-2006 18:06:49
Mine stay set the same for clover as alfalfa.
Reason being that the clover stem is larger so it will crimp more without changing anything.
Gary
FrenzFarms
04-30-2006 18:35:14
I'd try it at the same setting as alfalfa first. There is no magic setting for a given crop because of the variation in maturity from when one guy cuts to another, ground speed, etc. I personally have found haybines a lot harder to plug up than a lot of guys make it out to be. Nearly the only time I've plugged one is when I've unknowingly broken a guard and snagged a big wad of material before I realized it. Even then they'll usually clear themselves if you stop.
plumboy
05-01-2006 03:32:44
 Re: How close to set crimper rollers? in reply to FrenzFarms, 04-30-2006 18:35:14
Thanks guys.I am wondering if I even have them set close enough for the alfalfa because it doesnt crimp it that good.
Randy as in Randy-IA
05-01-2006 16:17:04
 Re: How close to set crimper rollers? in reply to plumboy, 05-01-2006 03:32:44
Check your roll pressure . Get that right and set the rolls so you can just see a sliver of daylight between them all the way across . I have a old IH 990 that works real good after I set the roll pressure right . You don't want the rolls to touch when turning empty though , at least on a 990 . And you don't want too much space in there either . And since rolls are probably never perfectly straight you have to spend a lot of time under there turning and looking , so try and get them as close as possible without touching . Good luck ...Randy
