Help with Grain Drill
JeffK-MN
04-30-2006 17:07:41
I got a old grain drill from a auction last winter. I can not find a manufacturer or a model number on it. But I have gotten parts off 2 other grain drills that look the same but so can not find any ID on them. All I know is that all of them are red with low profile rubber wheels. I'm trying to find out where to set it for seeding oats and grass.
If anyone can help I would appretiate it.
I have it all working now and just need to learn how or where to start. Thanks Jeff
JeffK-MN
05-01-2006 16:42:40
 Re: Help with Grain Drill in reply to JeffK-MN, 04-30-2006 17:07:41
Thanks it is a McCormick I found a part number whith the IHC buy it and used a wire brush and a white marker to see what the setting indicator said. Does anyone have a chart or a book that tells how many peck per acre? Thanks again Jeff
paul
05-01-2006 22:07:59
 Re: Help with Grain Drill in reply to JeffK-MN, 05-01-2006 16:42:40
My IHC I set up for not quite 3 bu oats per acre, around 2 bu of wheat or rye per acre. 4 pecks to the bu. Cut that by 1/3 or so if underseeding alfalfa and you want the alfalfa more than the grain.
--->Paul
Sid
04-30-2006 20:51:37
What I do is set it so that it will drop two seed at once. Then drill a little ways and count the seeds it dropped in a one foot square,usually 12-14 seeds. It takes alittle trial and error and some using a pencil but that should get you started.
sammy the RED
04-30-2006 19:53:42
third party image
Does it look like this one of mine ?
sammy the RED
04-30-2006 19:49:22
Not all grain drills have a grass seeder attachment on them.
It may be a IHC McCormick Model M grain drill ?
A picture would help.
