Baler
Randall Garner
04-27-2006 05:30:24
Does anyone know if you have to time a JD 214 baler? and if so how do you do it?
Thanks in advance
Randy as in Randy-IA
04-28-2006 11:55:39
 Re: Baler in reply to Randall Garner, 04-27-2006 05:30:24
As Dave said , run it by hand and trip it at least few times , ( the top of the flywheel moves forward ) more if you think something may be wrong . A operators manual is the most valuable tool you'll ever buy for that baler or any baler for that matter . A parts book is very handy also . There's some web sites you could check , just search for manuals or farm manuals or try ebay . If you get a copied manual be prepared to send it back and try another source till you get one that has pictures that you can make out the details in . It helps to see the pictures to understand the procedures . Good luck ! ...Randy
Dave H (MI)
04-27-2006 07:00:21
Well, yeah. Balers have to be timed right. If you look at the operation you can see it is pretty critical that things happen when they are supposed to happen. You need a manual and they ARE available so don't be a piker and head to JD and get it. Second, have you run it through it's cycle by hand a few times to make sure it actually needs to be worked on? Get the manual and play it safe.
