Which Drill?
Illinois Boy
04-25-2006 13:05:12
Guys,
I have narrowed down my search to two drills - both in very good condition. I"m gonna use it to plant mainly grass seed (hay) and a cover crop like oats or sometimes some winter wheat on about 60 acres. Both have grass seed and fertilizer boxes. Which would you go with?
a McCormick-Deering 8 footer or an International #10?
Thanks in advance....
Illinois Boy
04-25-2006 14:49:33
 Re: Which Drill? in reply to Illinois Boy, 04-25-2006 13:05:12
Sorry Leroy..
The McCormick is an 8 foot with 14 hole 7in. spacing Has grass seeder. Single disc openers with a clutch lift. All feed tubes look good. Tires and paint good as well.
Kept in shed.
The #10 is in the exact same condition but a 10 footer with dual openers / 7 in. spacing, grass seed boxes - just about the same drill as the McCormick - but of course not as old a unit.
Both of these drills have been well taken care of and not mistreated at all.
I�m also thinking of parts availability � but have acquired a reputation to �fabricate� when needed!!
Leroy
04-25-2006 15:04:11
 Re: Which Drill? in reply to Illinois Boy, 04-25-2006 14:49:33
I would think the newer unit would have more parts avaible and if you have enough power to pull it it would get you done a lot faster if time is limited by other commitments
Leroy
04-25-2006 14:16:56
What model is the 8'er? Both drills could be the same No. 10 or both the same 8' size. You are not giving us any information to use to help you. Single disc, double disc openers and other features.
farmertee
04-25-2006 13:14:30
I personally like the international 10. I use one every year to plant oats and seeding. Mine is a 13 hoe drill. I don't have the covering chains which I think would be a big help. Just my opinion.
