Model 72 NH Hay Thrower
roper6365
04-25-2006 02:45:31
The Thrower will turn if I spin the flywheel by hand but when I put the pto to it, it won"t work,,any help would be wonderful!
Catskill Pete
04-25-2006 11:24:07
 Re: Model 72 NH Hay Thrower in reply to roper6365, 04-25-2006 02:45:31
You might need to replace the belt that drives the Hyd pump. Over time they get worn too narrow and start slipping at speed and under load, and no they won't always make any noise so you can hear it slip. Turning it by hand it will still have enough friction to turn the pump slowly but not at speed. Also you should check that it has enough fluid in the reservoir and the filter [if it has one] is ok.
arrock
04-25-2006 10:33:37
make sure you have enough tension on the front belt that goes around the flywheel. there is alot of adjustment there. if it is too tight will send bales over the back of your trailer. do it little by little
Tim(nj)
04-25-2006 10:13:18
Is the shear bolt in the flywheel?
