?? on Ford 3pt disc
Joel WA
04-23-2006 06:35:15
I"ve located a Ford 7-8ft disc. It is 3pt but doesn"t seem to have linkage from top of 3pt to the disc to keep it all together. When hooked up it would appear to be in a float position. Great for discing, but not for traveling. Any idea what I"m missing, or if a chain would work. Hope I"m clear in what I"m trying to say. What HP tractor was this made for? I have a WD45 I want to hook to. Thanks Joel
Joel WA
04-23-2006 08:37:28
 Re: ?? on Ford 3pt disc in reply to Joel WA, 04-23-2006 06:35:15
Okay, guess wasn"t clear. Has triangle to hook to 3pt. I have a toplink. the triangle part only connects to the front of disc at bottom, not top. Maybe to it can float when down all the way. From disc side of top-link on top of triangle it needs some type of linkage. If I were to lift it only the front would lift as if the top wasn"t connected. Better? Hope so. Joel
Stephen in SOKY
04-23-2006 16:25:24
 Re: ?? on Ford 3pt disc in reply to Joel WA, 04-23-2006 08:37:28
Is it a "Flexo Hitch"? I've got one. A bar runs from the top of the triangle you mention, just below where the toplink attaches to the center of the rear gang. I know the bolt hole @ rear gang requires vertical bolt, so look for a hole just inside angle iron frame at center. Bar must have spacers around bolt at both ends allowing bar to move when unit is raised and lowered. I've got the Owners Manual, but you'd not likely get one even with part#. If you need the length to have one made, let me know & I'll measure mine for you.
lzybull
04-23-2006 07:22:06
Get a top link . Glenn
steveormary
04-23-2006 08:25:12
 Re: ?? on Ford 3pt disc in reply to lzybull, 04-23-2006 07:22:06
And do not use a chain.
steveormary
