NH 55 rake
stu in njo
04-22-2006 15:44:51
Can someone tell me how to get the bearing out of the bar? I would like to put grease fiting in the end of the bars were do they go? Thanks Stu
paul
04-23-2006 08:21:56
 Re: NH 55 rake in reply to stu in njo, 04-22-2006 15:44:51
They fall right out when they wear out. Took one out with a torch when it didn't. Should pull out, but can take some pulling!
Have fun getting the bar back in. As you cuss & swaer trying, you will note the geomitry of it all only allows all of one end plate to be slipped in at once, not just one bar. You _can_ work the rubber square back into the slot after installing loosely with a couple of screwdrivers, but it ain't easy. Anyhow, be prepared to spend some time getting the new bar back in....
--->Paul
stu in njo
04-23-2006 10:33:27
 Re: NH 55 rake in reply to paul, 04-23-2006 08:21:56
Thanks Paul I made up a puller worked great.Thanks Stu
Formerly PaMike
04-22-2006 16:51:03
I dont know how to get them apart, but I am not sure why you would want to. They are sealed bearings and we have had our rake for 20+ years with no problems to those bearings.
stu in njo
04-22-2006 18:11:37
 Re: NH 55 rake in reply to Formerly PaMike, 04-22-2006 16:51:03
One of the bars broke its 140.+ without the bearing or stud. Stu
