Plow and planter for Farmall H
Want a be farme
04-18-2006 14:38:13
I bought a good strong H. Now I need a plow and planter. I'm planning on going to swap meet in Lesuer MN. Any advice on what to look for to make sure I get functional equipment.
MN Bob
04-19-2006 06:48:32
 Re: Plow and planter for Farmall H in reply to Want a be farmer, 04-18-2006 14:38:13
When is the swap meet in LE Seaur? I may try to get down there. Have to go the the cities soon anyway. Bob
Want a be farmer
04-20-2006 10:37:41
 Re: Plow and planter for Farmall H in reply to MN Bob, 04-19-2006 06:48:32
April 28th-30th good luck
case411
04-19-2006 04:10:29
a farmall h will usally pull a 2-12 or a 2-14. if you have the one way hydraulics you can find or make a hydraulic plow out of an old trip plow. i have put cylinders on many old trip plows. so if you want to make life easier you can do this. We also used an old 2 row planter and a 13 row jd bean drill to plant with our h.
Leroy
04-18-2006 17:16:46
If you have hydrolics on the H then you can use a cylinder lift plow or planter, do not have to be trip type. Just unless you have very easy plowing ground do not buy a 2-16" as it would be overloading your tractor. We always pulled 2-12" here in heavy clay, second or third gear with the 11-12.4 X 38 tires, if you have the oversize 12-13.6 X 38 or larger that people like to put on then first or second gear so don't buy too big that you can't pull it
david e stephenson
04-18-2006 15:23:54
any good two bottom pull trip type plow will work on the old h and and ant 2-4row planter should be ok.i have a little genius 2 bottom plow and a old 490 j.d. for my old 47 h in s.e.iowa. good luck
