16A chopper
BarnYard4020
04-17-2006 19:20:31
I am trying to change the knives on my JD 16A green chopper.I have removed the wedges that lock the knife rod in and installed the special tool into the right side of the rod. I sprayed the rod the best I could through the wedge slots and knife slots but still can not get the rod to slide out.Any ideas would be appreaciated.
`Bernie in MA
04-18-2006 17:41:38
 Re: 16A chopper in reply to BarnYard4020, 04-17-2006 19:20:31
When I had to work on the underside of my 16A I chained the drawpole to the front of my dumptruck body and stood the chopper almost straight up. Made it a lot easier to work on. It's been 40 years but I don't remember having any trouble getting that rod out. But the chopper wasn't very old.
BarnYard4020
04-18-2006 18:33:45
 Re: 16A chopper in reply to `Bernie in MA, 04-18-2006 17:41:38
Sounds like standing it up like that would be helpful. I really think that if this machine was 20 years younger the rust would not be as bad on the rod. I need to crawl under there with a torch and see if I can get it hot enough and maybe spray some more penetrant while it's hot, and then maybe get the rod to budge.
Leroy
04-18-2006 05:14:40
can you get the rod to make a 1/2 turn, the flails will have wore into it creating a notch for them to be catching in. Will probably have to use a tank of oxygen on heating to get the rust to break loose. My no. 10 J D was before they went to that setup and had individual brackets with a if I remember corectly a 5/8" bolt for each one and they liked to get that notch in the bolt that you had to get exactly aligned correctly to get them out
BarnYard4020
04-18-2006 05:56:49
 Re: 16A chopper in reply to Leroy, 04-18-2006 05:14:40
No I can't get the rod to turn either way. I will try and use some heat on it and see what happens.
