Silage special Round Balers
Kent in NB
04-17-2006 17:17:13
Starting the big search for the perfect, used, Silage Special round baler. NH and JD are at the top of my wish list. Only because of the number of dealers within 150 miles. We would be doing about 1200-1500 bales a year. Likes and dislikes, all welcome.
barnrat
04-18-2006 05:52:24
 Re: Silage special Round Balers in reply to Kent in NB, 04-17-2006 17:17:13
I have a JD 335 that came with a silage kit. I have ripped most of the silage kit off and it works alot better for silage bales. I like the bales it makes although it can get finicky as you approach 70% moisture. JD balers seem to be over priced for what you get. My neighbor has a Krone he bought used bout 5 years ago. He does about 3000 bales per year. He has had very little trouble with it and it will bale anything. I've seen bales he made in a rain/snow storm that were more mud than balage, didn't bother that baler a bit.
Hay DR
04-17-2006 21:12:04
third party image
We have been a McHale Silage Bale Wrapper distributor since 1991 and have demonstrated these wrappers with every baler sold in the USA. If you want a roto-cut head in your baler then the Claas or Welger are the best balers. If you don't want the roto-cut feature then Vermeer or New Holland are the best because of the bottom drum roller that supports the weight of the bale. JD & Hesston use the same vertical chamber design and will bale haylage but will not come close to the density of the bottom drum roller balers. Dense tight bales with less Oxygen in the bale is the foundation of making good haylage.
RodInNS
04-18-2006 06:28:31
 Re: Silage special Round Balers in reply to Hay DR, 04-17-2006 21:12:04
I want to make some very clear points about baling silage, and it's not meant to jump on anyone here.
I have listened to a lot of bullsh!t over the years from local people who told me "you can't bale silage with a fixed chamber baler, because the bales are too soft". One of the guys that used to tell me that used to run a Vermeer. Now he runs the "other" green, the same as me.
I'm sure that "studies show", and theories have been presented where bale density has made a huge difference in silage bale quaility, and ensiling speed. I'm sure there is a paper trail...
But....
The number ONE thing effecting the quality of wrapped silage is maintaining the plastic, free of holes, after the bales are left to sit.
The second most important thing effecting quality is the time frame in which the bales are wrapped. They need to be wrapped as soon as possible after baling. Anymore than 12 hours, and you can expect results to go down hill fast.
The third most important point is forage dry matter content. This should be in the 40-60% range, with the best testing bales I've seen in the 50-55% range. If they're too wet, they turn to crap, or leach out, and too dry, they will not ensile.
To this end, the baler that will clean the field off at the right moisture content, ahead of the rain, and get a wrapper running quickest, or free up labor is the baler to have. The density of the bale is no doubt a variable, and denser is better.... but the above three points all have the ability to effect the bale quality far more adversly than the bale's density.
I make these remarks because the local crowd that had to have a hard core bale often didn't get their bales wrapped in time because they were still trying to get the field baled before it rained (we've all done that), or didn't look after them after they were wrapped, or they baled them soaking wet with the NH chain balers.... and they all got the same result. Sh!t. But they had a denser bale, for all that it mattered. We've wrapped probably close to 10000 bales on this farm, and bagged a couple thousand more before we wrapped any, and I've seen a lot of good bales. I've seen a lot of bad ones too.... and most of the bad were a direct result of one or more of the three reasons above. In real world conditions, it would be a figment of one's imagination to say that a hard core bale is a better silage bale, denser though it may be. In my mind making 25 dense bales per hour is an awful price to pay over 50 almost as dense bales per hour when the other half of the field didn't get baled. I'll go with speed of harvest every time, and for that, Claas is the only way to go.
If a person is not doing a whole pile of baling, and speed isn't a big factor, then mabey bale density is more important...
I still believe that the key point to remember is that of the variables that effect silage bale quality, bale density is well down the list.
Rod
Hay DR
04-18-2006 13:50:30
 Silage special Round Balers in reply to RodInNS, 04-18-2006 06:28:31
Most of the haylage harvested in KY & TN is grass hay, small grains, or a mix of small grains and grass hay. Since alfalfa makes up only 4-5% of the hay grown in these states most of that goes up as dry hay but some alfalfa does get harvested as haylage. Alfalfa has a higher concentration of calcium than grass hay so the sugar and moisture content needs to be closer to the optimum as mentioned by RodinNS.
You can not cut briars and expect 20% protein but you can expect 20% protein or more from orchard grass or a grazer rye. If one is harvesting Sudan grass the roto-cut option will do a better job than just baling Sudan grass as if it was just cut down but either will work. It is a given if you do not have a good seal on the plastic, you wasted your time and money. The Wrapper being set correctly with a good high quality plastic is a must. One of our best customers uses a Vermeer 554XL baler & a 991b McHale wrapper. The Wrapper was sold to them new in 1994 and they wrap 3000+ bales a year. 50% is alfalfa and 50% Orchard Grass & Rye mix. They also do another 1000 dry bales a year.
Kent in NB
04-18-2006 06:08:13
Thanks Doc.
RodInNS
04-17-2006 18:52:58
Kent,
I shouldn't go on too long about balers tonight... Wrote enough below... However, I can't say enough about the Claas 44S that we've been running. It's baled a lot of silage over the years. We had a demo from Agmar not long after they started bringing them in. We saw NH's of that vintage working (848), and it wasn't really a question. The Claas was about 4 grand dearer... I think in '87 or '88, but it was well worth the money. You might even look into the newer Rollant 250's or 250RC's. These balers start the bale easily, and keep going. The density may not be that of a belt baler, but that doesn't really matter anyway. Personally, I want an open throat, fast pickup, fast running, high capacity baler. Class fills the bill. To the point that the others should be ashamed to be in the field. Not sure on who the dealer is in your area.... mabey Hall Bros.? It would be worth a look.
Rod
Kent in NB
04-18-2006 06:01:40
 Re: Silage special Round Balers in reply to RodInNS, 04-17-2006 18:52:58
Hi Rod. I think you are right about Hall Bros.. I have talked to a few of the dairy guys in SW NB that are using the CLAAS Silage balers. Good reports all around. Only problem is new price is out of this world, and the few used ones I have found, are better left at the dealers yard. The Deeres and NH's are more plentiful and in better condition,for the money asked. I am switching over to baleage as finances permit. Big wagon, new tractor, and new discbine two years ago, baler and maybe a tedder this year, and an inline wrapper next year. Thanks, and I will look some more. Kent.
RodInNS
04-18-2006 06:42:12
 Re: Silage special Round Balers in reply to Kent in NB, 04-18-2006 06:01:40
Hi Kent,
You might take a scoot over to Kensington some day too. I've seen some green in their list from time to time, if you can deal with them. You could also shoot over to Port Williams.... VanOostrums are the dealer down there. You're sure right about the new price. They are dear. Another thought... if you are ready to buy. Call the sale barn in Truro. They're having an auction this Saturday. I doubt you'll find a Claas there, but there's often a few balers in the yard... sometimes a real nice one... and nicer gear usually gets stolen there. There was a really nice clean one last year.... fairly new NewHolland. Seems like it went for about 6g.... Just call Frank, see what's coming in. You need the number, let me know.
Rod
Kent in NB
04-18-2006 18:17:09
 Re: Silage special Round Balers in reply to RodInNS, 04-18-2006 06:42:12
Hi Rod. Went through the yard at Kensington two weeks ago. They had a few interesting balers,all colors.Was rushing for a cattle sale, and couldn't look closely. Bought my nh8160 from them, and found them really good to work with, both before and after the sale. My land ,they sure have a lot of stuff there! I have talked to Frank in the past. Don't think I can make that sale though. I ahve been making baleage for about 15 years now, used about 7 different wrappers, some good some bad, soft core and hard core. Wrapped in the rain,sun, and snow, and in NB and Ontario. The quality always seemed to be there as long as the moisture was good, sugar levels were plentiful, and you paid attention to the details(landing pads, patch holes quickly, and no short cuts). I have been using a CASE IH 3450(NI Baler) Soft core, non silage baler for my silage bales, for the last 7 years(200-250 per). I think i may have thrown out half a dozen bales. So, yes you can do without the dense bales. Sometimes, brain density can become a problem for some of the new operators. Aw , that wasn't nice! Your comments seem to indicate that the dense balers may have an issue with speed? I am doing 15-20 silage bales/hour and 22-25 / hour of dry hay. Are these new birds slower or faster? Good talking to you. Kent
RodInNS
04-18-2006 19:15:35
 Re: Silage special Round Balers in reply to Kent in NB, 04-18-2006 18:17:09
Hi Kent,
I don't know if the age of the balers makes a lot of difference in terms of speed or not. Like i said, I'm running a '88 model Claas Rollant 44S, equipped with a simple single twine tie system. I run the twine wand at full speed. That said, I do need to be careful not to bust up the bales if they are handled too much, or too agressively. They are under tied. But I'm cheap, and I hate waiting for them to tie. In terms of BPH, 35-40 is pretty average in a decent crop. We do rake with a 14' Kuhn rake, so I've got the big rows. That baler, with me running it, powered by a TS90, 12x12, at 6 mph has topped out at 55 bales in 60 minutes in silage, and 58 bales in 60 minutes in hay. That day I was helping a neighbour who had lost his old Hesston to a breakdown. He borrowed and old Massey of similar vintage, and was having trouble with it. He still had 50 acres flat, and rain on the way that night. Those were both 5x6 balers... mine is a 4x4. When he was working steady, I outbaled the massey 4 to 1, or probably about double the tonnage per hour. I would say the best I've done, on a daily average, in heavy first cutting dry hay, was 50 bales per hour. I've never seen nor heard of a NewHolland 848 being pushed beyond 35 bph on a darn good day. Comparing the Claas to those old closed throat balers like I mentioned above really isn't fair. They're just old old technology. My guess about the current line of Vermeer, NewHolland, or Deere balers is that they would not like being pushed in the same manner as I'm accostomed to, particulairly when starting the bale. You would generally take more time, and use more caution until it gets spinning. Your bale density and shape would probably go downhill at high speed too. The Claas suffers starting problems at high ground speed too, but under 5 mph it usually isn't a problem. I've baled as fast as 10 mph on lighter rows. Anyway, I've said enough. I already sound like a salesman.
Rod
Kent in NB
04-19-2006 18:24:02
 Re: Silage special Round Balers in reply to RodInNS, 04-18-2006 19:15:35
Hi Rod. I used to run faster,But my bale shape and weight suffered. So I slowed down and did a better job. Took a run to Sussex today and visited the big three(NH,CaseIH, JD). Arbings yard was almost covered. So much stuff, even the paths were full! JD yard had a nice display, but not much stuff to shop thru. Beyco had a good selection, but not alot of volume. Now one fella told me to consider the fact that Sliced bales will tend to freeze the sections together in the winter. This was news to me. He had sold to some and this is what happened to them. My thoughts were that perhaps they had baled at the wrong moisture. What do you think? I know you are almost as far South as the Hay Dr., and may not know what freezing feed is like, but a different opinion sure wouldn't hurt! Granted, this fella was trying to sell me a new, 2005 silage special, without bells and whistles, at a great price. His comment did make me think ,though. Awful windy day. Kent.
RodInNS
04-20-2006 11:05:54
 Re: Silage special Round Balers in reply to Kent in NB, 04-19-2006 18:24:02
Bales freezing, eh? I've seen enough of them frozen half way to the friggin center. Like you say, too much moisture is often the problem. To be honest, I got so sick of buying plastic, peeling plastic from frozen bales, and then paying to dispose of the plastic, that I just bought a harvester and built two bunkers. I don't regret it either. I'll likely wrap a few hundred this year again for the Newfs... but that's probably only going to be second cut. We'll see how first cut shapes up.
I really can't tell you how the rotocut bales handle, or act with regards to freezing. I can't really see it being much different??
I'm actually north of 46 here.... sitting in the middle of the great Bras d'Or. If there's a wind, I've got it. I've seen 3.5 miles wide of that channel freeze in 8 hours in a 40 mph wind.... and that's salt water. Cold... colder than a whore's heart...
Anyway, keep snooping around. I'm sure you'll find a decent baler somewhere.
Rod
Hay DR
04-18-2006 23:44:11
third party image
When it comes to tonnage per hour the Vermeer will have the greatest capacity of any round baler made in the World. The direct feed pick-up on the Vermeer coupled with the bottom roller design can bale at 10+ MPH without bale quality suffering. In fact the Old 1988 model 605 J is yet to be unchallenged by any of the other colors. The new Vermeer M balers dominated sales for 2005 when it was even a down year as well. Round balers sales for 605 balers were 10% below the 10 year average sales figures but yet Vermeer gained a substantial market position. In the Fall of 2006 the New Vermeer Rebel baler likely will be shown at the Sunbelt AG Show. Another New 5'x5' round baler design "The Big O" is slated to be released in 2007.
Kent in NB
04-19-2006 18:03:05
 Re: Silage special Round Balers in reply to Hay DR, 04-18-2006 23:44:11
Hi Doc. Your info is great,but I don't think we have a good sales and support network for Vermeer, up here. Heck, even Rod's favorite isn't well supported here. The main dealer for Claas ceased operations last fall, after the owner was killed in an accident, and the family did not wish to carry on. The Maritimes is pretty spread out ,compared to the American industry. Just the way it is. Keep showing us your good stuff, it may get us thinking some more. Kent
Hay DR
04-19-2006 19:25:39
 Re: Silage special Round Balers in reply to Kent in NB, 04-19-2006 18:03:05
Remember 80% of the hay harvested in the USA is dry round bales. Claas has it's main market following in haylage. When your main product is dry hay it is Hesston, John Deere, New Holland & Vermeer. Claas sells 200-400 balers a year in the USA while the big 4 sell about 2,000 round balers a year.
barnrat
04-19-2006 04:51:25
Vermeer balers are pretty good, but most farmers doing silage bales around here including my self have a baler with a processor or the next baler they buy will have one. 6-7mph in a heavy windrow on my JD 335 is plenty fast for me.
Kent in NB
04-19-2006 18:29:07
 Re: Silage special Round Balers in reply to barnrat, 04-19-2006 04:51:25
Pretty respectable, Barnrat. The 335 does do a nice job in hay. Neighbor helped me out last summer, and that's what he has. Kent.
Andrew from KY
04-17-2006 18:05:13
I can't say anything about the New Holland balers, having never been around one. However I really like the John Deere roll balers. We put a silage kit in a 466 so that we could roll alfalfa/oats for haylage, which did a real nice job.
