Leroy, Thanks for your responce. After doing as mutch research as posible, I have found that there is supposed to be a weight box that hangs on the 4" x 4" timber beam that goes from the hitch back past the gangs. The wieght box is able to slide along the beam, so as to adjust the load being applied to the gangs. To clarify the gangs, there are 6 sets of blades (3 blades to each set - 6 cutting edges) per gang, and are about 3" long (which gives a total cutting width of just over 6"). Each gang has the blade point curves pointed to the outside. This tends to throw the cut up dirt to the outside, which if used along the same path repeatedly, leaves a hollow in the centre of the path. Someone has (so it apears) replaced the link rods (the pieces that join the lever handle to the locking bold for the quadrant) with fencing wire. This is easy enough to replace with 1/8" rod, which would have been about the right size. What I really need is a digital camera, so I can post a pic" or 2 of it. Then, it would be easy for someone to give more information about it. Cheers, Phill.
