OT-Woods RM90 blade removal
Mike S
04-12-2006 14:46:48
Anybody out there got one of these mowers? I am trying to take the blades off which I feel are the original ones from the looks of them and I cannot see an easy way to get leverage to loosen the nut or bolt that holds on the keeper pin for the blades. The manual that I have does not indicate anything is lefthand threaded as on my RM59. Any tips would be appreciated. I have been soaking the nuts/bolts in Kroil for the last couple of hours. Not easy to get to since you have to reach into that little access hole to do it. Thanks
Bill in NorthCentral PA
04-13-2006 08:05:44
 Re: OT-Woods RM90 blade removal in reply to Mike S, 04-12-2006 14:46:48
If this is like mine, you spli a socket and extension down and remove the bolt holding the hardware in place. The shaft wants to spin, so I set the mower on a block of wood or top of a dirtpile. I often have to use a pipe extension on the ratchet, and mine turns off counterclockwise.
Good Luck,
Bill
