Seed Plate Numbers
Kevin L.
04-12-2006 10:05:53
I have a few JD Lustran seed plates and need some info about the numbers on the bottom. Have some with B0, Some with an * instead of a dash and some that in with an X.
1. is BO with 24 cells the same as B0-24...
2. is B0*24 the same as B0-24..
3. some end in X, what's the X mean..
thanks..
phillip d
04-12-2006 18:04:29
 Re: Seed Plate Numbers in reply to Kevin L., 04-12-2006 10:05:53
Hi Kevin,24 and 24x are the same as far as I know,24 is the number of seed slots on the plate.Look at the seed bag to decide which plates to use,it will say on the top of the bag what seed size you have and there is a chart on the back to tell you which plate will best fit the seed you have,i think the x refers to the number,ex B0 times 24,phill
