Box Blade
Hal/WA
04-09-2006 22:51:23
Today I bought a new King Kutter box blade that was on sale at a local farm store. It is 66 inches long and has 5 adjustable "ripper teeth". I had to figure out how to assemble it, because it came with no directions, but it wasn't too bad to get it working.
Late this afternoon, I mounted the box blade on the 3 point of my Ford 641D and went out into my field to see how well it would work. First I went to a couple of rocks I had located earlier, but had not been able to move with the regular moldboard plow, my old back blade or the tractor loader. The box blade was able to remove both of the large rocks, almost easily. I had thought that the only way I could ever move those rocks was with a large dozer or maybe explosives.... Then I tried moving dirt. I found that the box blade could mound up dirt much faster and easier than I ever could with the heavy back blade. I then used the box blade to remove some hawthorn bushes by the roots--the same bushes that stop my moldboard plow dead. It wasn't an easy job, but it worked.
Needless to say, I am impressed with my new toy! I ran out of daylight today, but hope to see what else the box blade will do over the next few days. I think the 66 inch blade is about right for this tractor--hopefully it will hold up. This is the first brand new implement I have ever bought. I never see used box blades for sale around here.
CaptRon
04-13-2006 08:47:55
 Re: Box Blade in reply to Hal/WA, 04-09-2006 22:51:23
I have a KK 60" box blade on my 960 that I've had to reweld a couple of times. But then I wail on it pretty hard. I found that cutting a tree off short and then hooking the rippers under the stump and coming up on the 3pt while pulling forward will pop most of my stumps out of the ground. Pulled about 30 stumps up to 9" diameter like this. You can order parts directly from King Kutter"s web site. I saved almost half doing this rather than going through TSC, and in half the time, delivered to my door.
They also have parts lists so you can see how it all goes together.
The weld on the two corners of the box that holds the rippers is weak so check it for cracks and reweld before it bends out of shape, I had to bend mine back with a 6ton jack and then weld it all the way across on the top and bottom. The factory weld looks good but has very little penetration. Good Luck,
CaptRon
Crem
04-11-2006 17:38:26
Yup, a box blade and a landscape rake are all that you need to do a lot of landscape work. I hardly ever use the regular blade anymore. Both of mine are King Kutter and they have taken a lot of abuse. You really need both implements. The box blade to dig in and move things around and the landscape rake to smooth it out. I add some weight to the rake when I need to pull more dirt or gravel. A 5' box blade and a 7' rake works best for me.
MN Bob
04-11-2006 06:45:10
So if you wanted to level some low spots in the field using any of the older tractors, how do you control the box height without a "float" postion? Been thinking of trying that before planting this spring?
Wild Bill
04-11-2006 13:09:37
 Re: Box Blade in reply to MN Bob, 04-11-2006 06:45:10
Bob, if you the "float" as you called it, you probably need to drag something like a cross-ty. that will help fill in the low spots. An old box spring set would be good too, really just anything heavy and flat will work to smooth your field.
Don-wi
04-10-2006 05:24:27
We have the same one I think, and just this weekend I ripped up the gravel in the driveway and then smoothed it back out. It was pretty wet when I started but about 1/2 hour later it was bone dry. Works great to get rid of the mess of a wet/muddy driveway.
Donovan from Wisconsin
