brush hog slip clutch
leeinmass
04-06-2006 11:52:09
Just got my first slip clutch for a five foot brush hog. To what extent can I adjust the pressure on the slip discs? Or should I just leave it where Tisco set it?
Thanks, Lee
Jerry/MT
04-06-2006 16:42:19
 Re: brush hog slip clutch in reply to leeinmass, 04-06-2006 11:52:09
If you know who the manufacturer of the unit is, call them up and have them give you the spring height required for the proper tension on the clutch. Once you have that you can keep it adjusted properly. I take the tension off my clutch in the Winter and readjust it to the proper spring height in the Spring.
Princeton Bill
04-06-2006 12:10:22
I wouldn't adjust the slip clutch until I had used the machine. A new one should not require any adjustment to the slip clutch. If the machine is used it may need some adjustment, but as I said I'd try it first. The last thing you want to do is get it too tight and break something on the machine or in the tractor.
leeinmass
04-06-2006 13:21:55
 Re: brush hog slip clutch in reply to Princeton Bill, 04-06-2006 12:10:22
Thanks, Bill. I won't tighten it, but I was wondering about the possibility of loosening it a bit since the clutch may be a bit oversized.
phil lowe
04-08-2006 04:36:02
 Re: brush hog slip clutch in reply to leeinmass, 04-06-2006 13:21:55
I've got a bushhog I bought with my old ford 3000 was going to start using it soon ,It didn't have a slip clutch ,Should I be getting one?
supergrumpy
04-08-2006 08:09:55
 Re: brush hog slip clutch in reply to phil lowe, 04-08-2006 04:36:02
nothing wrong with a shear pin setup, as long as you have aa actual shear type bolt in there
stumps or big rocks or bedsprings are hard on the pins
if you set your clutch too losse, you will hear the blades stop turning and smoke comes out, cinch the bolts down a bit (evenly)
