International #8 plow
Scott-mn
04-03-2006 13:43:50
HI I am wondering if anybody has a diagram or a parts list for this plow. I can read part # from the share which is 515698R5. I also have part # for the landslide 520184r1. I can get both of these from case international. My question is can anyone get me the part # for the point. I cannot read the numbers from this piece. Thanks Scotty
RegularRog
04-04-2006 16:45:03
 Re: International #8 plow in reply to Scott-mn, 04-03-2006 13:43:50
If you have plow chief bottoms the part # for
the point is 526772R11. Be prepared to spend
some money though, because they run about $80.00
a piece from case.
Hugh MacKay
04-03-2006 15:37:01
Scott: I thought I was going to be able to help you, however the parts book I have on plow bottoms is old enough all part numbers are PO numbers. It would be almost impossible to give you a number as there were several different bottoms used on No.8 plows
Are you sure the number 515698R5 is a share part number, sounds like a moldboard number to me. Besides the point and share on No.8 plows is all one piece.
Finally, I'll give you a bit of advice when buying old plow bottom wear parts, take the old one with and they can match it up. If they cant, you are talking with the wrong partsman.
