JD 7000 plateless 4RN planter question
Woodan
04-02-2006 10:19:59
Is there a way to determine the age of my "new" planter by it"s serial number(047240)? I"m assuming it is from the 70"s but am not sure. I need to get a operators and parts manual and am not sure which one to get.
JMS/MN
04-02-2006 12:22:06
 Re: JD 7000 plateless 4RN planter question in reply to Woodan, 04-02-2006 10:19:59
Double check the sprockets in the seed transmission. Early models had sprockets with fewer teeth- 7,9,11,14, etc. Later ones had 14, 18, 22, 28 etc. teeth. Ratios were the same but it's easier setting the right population if the book matches the sprocket setup.
Doug in IL
04-02-2006 10:47:15
My chart says it's a early 1977 model.
woodan
04-02-2006 13:30:17
 Re: JD 7000 plateless 4RN planter question in reply to Doug in IL, 04-02-2006 10:47:15
Thanks. Where did you get this chart from? Is there a way to get more information on the planter based on the serial number?
Doug in IL
04-03-2006 05:49:12
 Re: JD 7000 plateless 4RN planter question in reply to woodan, 04-02-2006 13:30:17
I printed the information off the internet. I think it was posted on this site.
woodan
04-02-2006 13:14:40
