moldboard extension????????
BUDD
03-31-2006 03:33:56
I have seen on some of the old plows that have a plate attached to the moldboard towards the back (it is like an extension). I assume that this helps cover trash. It is not in my parts book for the JD 44. What is this called and what is it for?
Thanks for the info BUDD
wisconsin
04-19-2006 21:28:54
 Re: moldboard extension???????? in reply to BUDD, 03-31-2006 03:33:56
We have lots of rocks, so going fast enough to make the furrow lay down is a problem. I've found old knives off of a chopper work very well. They are already curved just about the right amount. Works good for us.
R. Freshour
04-01-2006 17:49:54
I wouldn"t use them in rocky fields. Got two plows with broken moldboards because of those.
the tractor vet
03-31-2006 08:01:33
If ya can not find what you are looken for i have made up extenshions a couple times before by using flat stock , now i do not remeber the excat name or # of the steel that i used but it was tougher the regular mild steel and was a bear to drill thru as ya had to use Tap Magic then we would heat it and make a slight twist and grind the corners for a littel radious they worked good enough for us.
JMS/MN
03-31-2006 08:04:02
 Re: moldboard extension???????? in reply to the tractor vet, 03-31-2006 08:01:33
High Carbon steel? Would be tougher then mild steel.
the tractor vet
03-31-2006 10:25:18
 Re: moldboard extension???????? in reply to JMS/MN, 03-31-2006 08:04:02
It was tougher then high carbon as i have used that stuff before , my steel supplyer had some of this stuff in 3/8th x3 and said that it was tough and beleive me it was .
RodInNS
04-01-2006 14:41:59
 Re: moldboard extension???????? in reply to the tractor vet, 03-31-2006 10:25:18
Something like 425 wear plate mabey? I think they call it QT1000 plate now. It's just a quenched and tempered plate. Generally used for plow blades and such, and needs to be hot formed. It is just barely drillable. Much easier to pierce with the torch.
Rod
paul
03-31-2006 08:33:32
Old car or truck spring.
--->Paul
Leland
04-01-2006 16:27:51
 Re: moldboard extension???????? in reply to paul, 03-31-2006 08:33:32
I used broken truck springs for ripper points 1 time they were better than factory ones .
JMS/MN
03-31-2006 18:09:03
Yeah- wouldn't be the first time car parts were recycled! Hey- didn't see you wave when I drove by the other week- must have been busy?
ET
03-31-2006 04:56:30
Budd, The moldboard extensions help roll the furrow a little farther like Hugh said. They are real helpfull with the newer JD bottoms. The extensions are not in the plow parts book and niether are any bottoms. Deere has two sepatate parts books for plow bottoms. One book has all the old syracuse and john deere bottoms in it and the other book includes the HS, NU, and metric bottoms. The only extension available is probably going to be the one for the HS and NU bottoms. That one will probable work on the older bottoms too.
Hugh MacKay
03-31-2006 04:05:39
Budd: That extension you often see was designed to give a bit better roll to old sod. Old sod can quite often be difficult to turn, often times furrows will stand on edge, yes even roll back as you move along the furrow. Very annoying if your the guy on the tractor seat. Those extensions simply lay it right down in place. There has been many a 4 letter word uttered from a tractor seat trying to plow old sod without those.
They probably do cover trash better as well, but that was not the original intent.
