Not exactly an implement, Gehl Skidsteer
Errin OH
03-27-2006 18:26:08
I recently purchased a Gehl 4400 skid steer. Thing runs great and works like a champ. However I did run into a couple small problems.
Easy one first. One of the bucket cylinders in leaking a bit. I was lookin at it to night and wonderin how you get a new one in there. Is the piston bolted on like the China cylinders? I may just go ahead and replace all four if there that easy. If I have to remove the extension pipe from the end of the ram, I don't know may just do the one. I have done that before and it was a -----.
Second, This one may be a little harder. When you lower the booms it will sometimes come down at an angle (left hangs to right drops). Not always and not always at the same height. When it does this it slows way down and you have to wait for it. Sucks if there up there a bit. If you try to power it down the relief valve can be heard kicking in. Usally put it in float mode and wait. I can't really see a reason. Nothing bent, some wear, but nothing catching. And they do continue to drop. Just very slow. There is some kind of device on the cylinder on the left side. Is that some kind of flow control that is kicking in slowing the decent? Mabey some kind of safety feature for blowing a hose?
As you can tell I have got the manual just yet. Working on that. Thanks
Wayne in Pa
03-28-2006 14:54:34
 Re: Not exactly an implement, Gehl Skidsteer in reply to Errin OH, 03-27-2006 18:26:08
We have a 4400 and have had the same problem. The valve in the lelt lilt cylinder is connected to the key switch ( when the engine is running the valve is open when the switch is turned off the valve is closed). Our problem was a partly broken groung wire when it made contact in worked fine when the wire was open the boom would hang up. Check all the wire to the valve.
R. John Johnson
03-28-2006 00:30:25
Errin
Not sure about your first problem, but I would bet that the device you are looking at on the lift cylinder is a solenoid valve that is a safety feature. If you get up off the seat, a electric circuit is broken and the valve closes, preventing movement of the liftarms. If that is what it is, find the problem and fix it. DO NOT bypass that safety feature. Lots of people killed when the liftarms accidentally lower on them as they get out of the machine. Call Gehl's service department in Madison, South Dakota. They are very good and should be able to help with any questions or to get service parts. The phone number used to be (605) 256 6622. Good luck.
John
Errin Oh
03-28-2006 07:50:14
 Re: Not exactly an implement, Gehl Skidsteer in reply to R. John Johnson, 03-28-2006 00:30:25
Thanks John, I did see the switch under the seat when we replaced the seat. I don't recall any wires attached to it though. However I do recall seeing wires running to the side with the valve you refered to.
Thanks again.
Errin
