hay wagon tires size
jdjack
03-26-2006 17:45:38
I bought a hay wagon last year. Is a steel rack, the floor is gone and the rack disassemblied laying on the two stringers. It is a kasten running gear. I think that is has 6? hole rims and car tires on it. Rack is 9x18. Want to put 11L-15 floation tires on, but I don't think that there will be enough room between side of tire and gear, in the front. Looks like they might fit in rear. Is there a height diffence between 11L-15 and 9.5L-15? How do i tell the difference between tonage of gears? Also how far should the front and rear axle be from the ends of the wagon?
Thanks
JDJACK
rgvtx
03-26-2006 18:55:30
 Re: hay wagon tires size in reply to jdjack, 03-26-2006 17:45:38
third party image
Can"t help out much, but here is a link to a tire size calculator I saved a long time ago. Just checked and it"s still there. I might be helpful to you as you can enter a tire size and it will give the dimmensions of the tire.
