IH Mower ID. question
Binder-Man
03-26-2006 15:52:25
After all these years,I went up and pulled our old mower out of the tree line that fit on our F-20. It has the draw bar type mount, 7ft. cutter bar, has the pivoting rear steel wheel and has the v-belt drive. Could this be a model 16 they started making this model in 1940. Does anyone have a good picture off one of these mowers, I am missing the lifting handles for it,and I would like to find an owners manual for it, Thank You for your time and help on this project!!
Binder-Man
Binder-Man
03-27-2006 19:18:33
 Re: IH Mower ID. question in reply to Binder-Man, 03-26-2006 15:52:25
Don L C I know what you are talking about on the rubber tired one,we have one of them also,I never knew what model# it was. The steel wheeled one is very simular to it.Thanks for your help on this, I've been looking for a picture of one but no luck yet..... Have a Great Day!!!!
Binder-Man
Binder-Man
03-27-2006 15:42:15
I looked in my book 150 years of IH by Wendel,the model I have is not in the book. The frame coming back to the wheel is made of channel, the mount to the tractor is heavy flat stock, which looks like a draw bar,if you look from the draw bar to the back it looks like the letter A with 2 braces running between the channel frame rails. The piviting steel wheel on the rear has 10 spokes in it, we were always told it was made for our F-20,Wendel's book mentioned these but does not show them or tell what model they were, I checked the frame all over and can't find any nunbers, just IH stamped on rear wheel assembly and on cover over pitman arm where it attaches to cutter bar. I will try to get some pictures of it,but with my hectic days anymore this might take a while. I hope this might help a little, Thanks again guys for your help and time!!!!
Binder-Man
Wayne Swenson
03-26-2006 19:42:06
Maybe a #27? They were made to fit many models including JD.
Hugh MacKay
03-26-2006 17:59:31
Binder-Man: It's not a 16 as they were fully mounted with no caster wheel. My book is not within reach tonight, unless someone gets it foe you I'll come back in the morning.
A little further description will help, describe the frame going to the caster wheel, is it pipe, angle or chanel.
IaGary
03-26-2006 19:33:29
 Re: IH Mower ID. question in reply to Hugh MacKay, 03-26-2006 17:59:31
In the book by C.H.Wendel the only mower made in 40 with the cast rear wheel is the No.12-B or No.12-QA.
The QA had some kind of quick hitch design (not the fast hitch that came out on the super C).
Hope this helps.
Gary
Don L C
03-27-2006 18:55:56
 Re: IH Mower ID. question in reply to IaGary, 03-26-2006 19:33:29
We had a mower like you describe....the wheel had a rubber tire.....it was a IHC - 27 V---year 1948....
