more info on the NI hay rake
Greg C
03-24-2006 07:03:36
First off, thanks Errin, looks like you're right on the colors. Got her cleaned up a little and was able to see some paint.
In cleaning I also found the tag, it says New Idea Lot No. R118. Anyone know about these? I'm going to try to get a little research done today, see what I can learn.
Leroy
03-25-2006 18:32:13
 Re: more info on the NI hay rake in reply to Greg C, 03-24-2006 07:03:36
I did not have time to check the lot number but from the other post it would be the first year for the 4 bar rake-tedder combination, before that 3 bar with no model number. A few of the parts have to be made now as no longer avaible and I have several here now for rebuilding as they are very much in demand in some Amish areas bringing up from $500 to ????. Where are you at? It was built at Coldwater, Ohio and the orange paint is called Bittersweet and the green is very simular to Oliver green
Greg C
03-27-2006 11:19:31
 Re: more info on the NI hay rake in reply to Leroy, 03-25-2006 18:32:13
SW Iowa, south of Villisca.
Leroy
03-27-2006 17:33:02
 Re: more info on the NI hay rake in reply to Greg C, 03-27-2006 11:19:31
Just too far from eastern Ind & Ohio, Don't know if there are Amish out there or not but where I live I am in the center of a 200mile radious of over 90% of the Amish in the USA and less than a 100 mile from the largest and 60 mile from the second largest Amish setlements in the states
Greg C
03-25-2006 05:25:28
Thanks Keith, any idea what it's worth? It works just fine but I don't really need it. I'd like to see someone who will put her to work get it.
Keith D
03-24-2006 15:13:48
R118 lot was built in 1948, this is a model 4 New Idea rake.
