Planter Set Up?
Gene Stevens
03-21-2006 21:20:49
I have a two row field made planter. Everything works on it. I have not been able to get it to drop seed consistenly...any suggestions on how to set it up? Thanks in advance
Jerry (AL)
03-22-2006 15:10:06
 Re: Planter Set Up? in reply to Gene Stevens, 03-21-2006 21:20:49
Name would help. Assume three point.
Does it have chains that run off the presser wheels that turn the plates?
I have a Covington 2-row three point.
That planter seems to like to set it up so the drive wheels when up are just off the ground. It also seems to like settled ground, not freshly disked ground.
Might could help if knew more.
IaGary
03-22-2006 04:54:26
Make and model would help but if it is a plate planter are you using the right plates for your seed size.
Gene Stevens
03-22-2006 09:27:18
 Re: Planter Set Up? in reply to IaGary, 03-22-2006 04:54:26
I have no idea of make or model. It was part of a farm auction and I got it for $5.00. The seed drops as it should. The drive wheels do not always turn even though they freely turn. It has something with the way I am /am not setting it up for ground travel. Thanks Gene
