NH 248 rake
BradB
03-21-2006 03:30:36
Need to replace the bearings and seals in the gear box. Are these parts only avalible from New Holland Dealer or is there other sources? Guessing it would be just easier to go to the Dealer. Any tricks to getting the gear box apart?
BradB
03-22-2006 04:24:12
 Got it apart in reply to BradB, 03-21-2006 03:30:36
Got the gear box apart and Nh Dealer sent me a drawing of the parts. Found some water and oil in the gear box. Book says to run grade 2 grease not oil. Any way going to replace the bearings and seals and u-joints. Paint her up and wait for the hay to be cut.
BradB
03-21-2006 03:34:20
 oops 258 rake in reply to BradB, 03-21-2006 03:30:36
its a 258
JMS/MN
03-21-2006 07:56:46
 Re: oops 258 rake in reply to BradB, 03-21-2006 03:34:20
On older rakes there is an access panel to take off, and a cap on the side- looks like a wheel bearing cap. Pop that off with hammer and wedge-type chisel. Underneath is just like on a wheel bearing- cotter key, nut, washer, bearing. Remove that and shaft slides out of other end, which has another bearing and seal. 258 likely similar.
