loader working slow
fudpucker
03-20-2006 02:56:51
I have a Farmhand loader on a 4020D. The loader is plugged into a set of remotes on the rear of the tractor. Recently the loader has been working ver very slow. When I first start the tractor it won't work at all. I have to let the tractor run for about 15 minutes and then it will barely raise up. If I run it for a while and it begins to work ok. Then sometimes it will begin not working again. The tractor has plenty of hydro fluid and I notice if I take the tractor out of gear when it is not working it begins to work faster. I used this remote a few weeks ago to move a batwing bushhog. I have been told I have air in the hydro line. If so how do you get it out? If that's not it what do you guys think? All other hydraulic operations are working fine. Any thoughts are appreciated.
Fud
Test
05-31-2006 05:41:03
 Re: New Holland 850 Round Baler Manual in reply to dieselcrew, 04-10-2006 05:54:57
test
J. Schwiebert
03-20-2006 03:17:23
 Re: loader working slow in reply to fudpucker, 03-20-2006 02:56:51
In a sense for the air angle. However when was the last time you changes the transmission filter?
