hydraulic cylinder
tery
03-16-2006 21:57:30
can i turn a double acting cylinder in the a single actin cylinder. by way of a breather or something where i take out the one hose.
Glen in TX
03-17-2006 03:27:09
 Re: hydraulic cylinder in reply to tery, 03-16-2006 21:57:30
They use to make fitting plugs with a sintered bronze filter in them just for that purpose. Ask at tractor supply places or local industrial bearing hydraulic places for a filtered breather. Can also find them at surpluscenter.com
benny2
03-17-2006 00:36:23
 Oil sump Re: hydraulic cylinder in reply to tery, 03-16-2006 21:57:30
You can do that but you must have an air filter to keep it clean. If there is space you can also just intsall a non pressure sump tank that holds the oil for the none pressure side. It will suck the oil back in the cyl when free return.
Hoenes
03-18-2006 13:21:02
 Re: Oil sump Re: hydraulic cylinder in reply to benny2, 03-17-2006 00:36:23
We converted a dual action cylinder to a single action, simply by removing one hose, and putting in a pipe plug. I don't remember if it was the upper hose or the one at the base of the cylinder. It should work on anything with enough weight to lower itself.
